Can make your own pentode and beam tetrode models using paint.kip from here:
Model Paint Tools: Trace Tube Parameters over Plate Curves, Interactively
Paint.kit works equally well for triodes.
Screen capture the curves and save as a gif or jpg file.
Runs from command line and requires java. Once running it is not too hard to get the hang of curve matching. (practice makes perfect)
Please share trusted models here: http://www.diyaudio.com/forums/tubes-valves/200450-gm70-other-ltspice-tube-models.html
This site disappeared some time ago, but has reappeared:
Valvole e Matematica
These Triode and several Pentode parameter model generators are Excel based and seem to work. - Read the texts.
John
John
