Hello
Anyone did try that preamp ?
How does it sound compared to other high end preamps and diy preamp ?
http://thunderstoneaudio.nav.to/
I would not use the MC section, I would do that version;
Thank
Gaetan
Thank
Gaetan
jerluwoo said:Well the pictures are so bad no one can see the circuit ....
Pictures look fine to me. Can't comment on the circuit though, sorry.
the "search" function found these on this forum :
http://www.diyaudio.com/forums/showthread.php?s=&threadid=81575&highlight=
http://www.diyaudio.com/forums/showthread.php?postid=109321#post109321
there may be others ...
mlloyd1
mlloyd1
gaetan8888 said:Hello
Thank
Gaetan
The Analogue Addicts Phono Preamplifier 2006 Edition
Hallo Gaetan,
there is a thread of this schematic in the forum.
"The Analogue Addicts Phono Preamplifier 2006 Edition", maybe there you can find s.o. who already built it up.
Looks very interesting. But would use Black Gates in the signal path.
Sam
Hallo Gaetan,
Sam
El Cheapo Thosten Loesch Kuei Yang Wang The Analog Addicts
Thorsten Loesch ( 'The father' of all DIY GAINCLONES !! Inverted LM3875 Chip Amps)
has designed this wellknown phono amp.
He is diyAudio member Kuei Yang Wang
http://www.diyaudio.com/forums/member.php?getinfo&userid=3984
He has posted lots about this preamp. Unfortunately he is no longer with us.
Like some other good members he has found better things to do and maybe better places to be.
We go where we can feel welcomed & appreciated, dont we .. dont we ..
Here are some of Kuei Yang Wang writings, about El Cheapo:
Analog Addict's (El Cheapo) PCB
Most people, like you, would build for MM pickup
and not use the MC Gain section.
Regards lineup
Thank, Gaetan
Regards lineup
jerluwoo said:Well the pictures are so bad no one can see the circuit, not going to get any response if we dont know what the circuit is. Being a gif you should be able to attach to your post without using a host with popups.
Hello
Did you clic on the images and clic again on the large size image to get the full resolution image ?
Gaetan
- Anyone did try that preamp ?
