anybody know this small f-r speaker/parameters?
hello
good 2013:hohoho:
last time I bought failured ipod/radio player Miedion 8503.
inside were those speakers marked only UPS 8Ohm 5W.
the diaphragma diameter is ~6,5 cm.
I want to stack it in PCV tube enclosure and use with small V to I amp.
what could be optimal parameters for it like Q, Fs etc?
thank you in advance!
... anyway...
the first rough test was very disappointing
strong pipe resonance and the bass weaker than I expected, mid/trebles good, very wide stereophony.
After some time of listening I have got to used to it
but I think: do not walk this way:nownow:
Founder of XSA-Labs
Joined 2012
Pawel,
Before you give up on that PVC pipe speaker, put some pillow stuffing in it and listen. Or if you don't have any lying around, try fabric, towels, sponges, etc. Anything porous but damps sound waves. It might sound a lot better. Driver recommendations? If you are in the 3 to 4 inch driver size range, my favorite is the Vifa TC9FD. I have heard good things about Tang Band w3-881si. Both are budget drivers at $12 and $10 respectively in the US. The foam I am talking about is like this Amazon.com: Auralex 2SONO48CHA 2 Sonomatt Foam Panel, 48 2- 4'x8'x2, Charcoal: Musical Instruments
Regards,
X
