Hello Guys,
I just finished putting the GC together. Sounds great, lots of power (about 100 watts per channel). However, it's humming (in more ways than one). It's dead quiet when turned on, with the speakers connected. When I connect a source to the RCA jacks, such as a CD player, I get a low hum through both speakers. Disconnect one channel (either left or right) from the RCA jacks, and the hum stops. It only hums when both channels are connected. Any idea why? Thanks.
Hong
Hong
Everything is properly grounded.
i take the hum is there with the volume all the way down? how bad is it with your playing music?
I don't have a pot connected to the amp yet. The hum is there as soon as I connect the CD player. May be I should wait for the Alps pot to arrive...
Good looking amp ! Is it bridged or paralleled ?
Maybe the grounding should be done this way : put the RCA ground on the chip's ground pin, ground everything that is related to small signals (feedback, input resistor...) on this pin, then link this pin to the PSU ground. I may also suggest using a 3ohms resistor to connect the case to the ground, instead of directly.
Hope it helps
Hope it helps
Forget your star ground.
Connect the grounds of both amp PCB's with heavy gauge wire. Run grounds from rectifiers boards directly to the point central on that wire.
Run signal grounds directly to the boards. I assume each rectifier board serves one rail.
This should fix your ground problem.
fcel said:The wiring diagram is wrong, you said. Then I better delete that diagram from my hard drive....
The diagram is OK. I'm the author.
Upupa Epops said:....This wiring diagram is wrong...I see there several ground loops...
Use bigger glasses.
It's bridged. Ca fait bon de parler avec un Francais. Merci.
Hong
- Chip Amps
- Another Finished LM4780 GC
