Of course you can! Thas why I just coloured the AD1865 column. Please check on sheet 2 what you get therefor to avoid uclarity.
I have just choosen the resisitors, where references were added in the original BOM!! So some are missing!! I any of you have some proposal for the still "open" resistors, or you know anything from the main thread, feel free to propose here. I'll try to look if either Digikey, Mouser or RS supplies these parts for reasonable prices. I'd appreciate this.
Cheers Ernst
Cheers Ernst
Other DAC parts
Ernst,
Don't you want to add other DAC End parts to the digikey order as well?
I would be glad to have as many part as possible from one order
Like: 7 x TL431, 12 x 1N5819, 3 x 200 Ohm trimmer?
and maybe the 120uH inductor as well, if we know which model is better there.
Thanks,
Zsolt
Ernst,
Thanks,
Zsolt
Reichelt Parts
Added some parts from Reichelt. Prices are their online prices. I may raise them a little bit since they always take shipping fees, regardless the size of the order. Have to look which trimmer will be the right one. Prices vary by formfactor. So don't take the prices too serious, but they will be somewhere in that range and much cheaper than Digikey. Regarding quality, they usually deliver good quality, not superior, but don't know if Digikey does in that case.
Ernst
Ernst
I think that you have to split the Panasonic caps column to more detail. If I 'm not wrong,C8 and C9 47uf caps are mutualy exclusive with the JJ 50+50 so there is no option for someone to have C6 47uf and a JJ. So I suggest to put a separate column for P13563-ND.
Furthermore I would suggest the following columns:
604-1066-ND (ELNA Silmic II 220uf 35V) for C3,C9,C15,C5,C11,C17 for Salas PSU and C12,C13,C14 of I/V PSU
P11669-ND (Panasonic ED 100uf 450V) for I/V PSU C5
High End Audio - Electrolytic capacitors explains pretty good the reason for the silmics
Tassosk, you are right. I made this change. Thank you.
Regarding the ELNA's: Why you'd like to take 35V, since there is a 220µF/16V type for half the money available.
If I'd add this, I'd choose a 220 µF type. Found three wit different diameters. Have to look at home.
Ernst
Ernst
sudgen: change done. thanks!
tassosk: couldn'd find any 220µF/35V capacitor, except the ones, which were oscons recommended for. neither in andreas drwings, nor in the BOM. thats why I added 16V Silmics to the spreadsheet so far. I don't replace oscons by Silmics, because I already have the oscons in my box.
Cheers Ernst
Cheers Ernst
Cheers Ernst
No problem.
Could we add the P11669-ND (Panasonic ED 100uf 450V) for I/V PSU C5?
(unless there are better alternatives)
Where did you bought the oscons? If I couldn't find a good(cheap) source I'm thinking of replacing the 220uF with Silmics.I don't replace oscons by Silmics, because I already have the oscons in my box.
@ tassosk:
I've been thinking about that. Regarding better opportunities, I'm talking to another DIY guy these days and will go through the parts again with him. I'll post the outcome and alternatives, which I wanna go for before I'll close the GB here. I hope to close it around next weekend.
@vzs: Never found a really cheap source as well. Osscons are expensive. Bought them from shop www-audiotuning-de. Haven't found the absolutely right values, but took 180µF and 47µF.
Ernst
Ernst
@ tassosk:
Ernst
I don't know the prices, but here B&D Enterprises - electronics, projection lamps for hitachi, sony, mitsubishi, panasonic, samsung you can get most types OS-CON SP series Ten Four LTD
I took mine from partconnection SG 47 20v and SP 180 20v. Priced reasonably
Yepp. And 12 on the Salas board.Please take note of Diodes on the HV-supply total 7pcs only.
1. 4pcs of 1N5062 are D1, D2, D3, D4.
2. 3pcs of 1N4007 are D6, D7, D8.
- Group Buys
- Another European AD1865N-K GB
