Mooly said:
You need to measure these with a low pass filter on your DVM. Say a 10 k and 1 mfd. There could be a lot of HF "rubbish on the outputs which confuses things.
Can I have my dinner now please
Dinner ? At this time? Are you in Japan?
Anyway, bon apetite..
AndrewT said:http://www.diyaudio.com/forums/showthread.php?postid=1283350#post1283350
for a fuller explanation of the issues.
Of course..
The old topic! I will build a DC Servo, sooner or later!
As Capain Mainwaring would say " Ohh, haven't got time for all that now "
It's dinner time !! Hungry!! Need feeding !!
No problem at all ? If you null it even that will reduce to zero, but be careful. It's not always straightforward measuring such things, and I would again use a low pass filter on the output to get a "truer" reading.
Does your meter actually read 0.000volts with the probes shorted ? If you swap the meter leads round does it show -0.1mv or something different
Mad thoughts as you do, not just from todays posts but going way back.
Regarding power amps -- have the error signal fed to a sample/hold circuit that only operates at switch on for a minute or so and then say every 5 mins after that, just for long enough for a new error voltage to be aquired. Problems, well I suppose if there were significant drift of the offset then each time it corrects that could be audible.
Captain Mainwaring again " Your getting into the realms of fantasy now Mooly "
Next ? (Back to the preamp now) Use the output of the servo to correct the OPA via it's offset null terminals. That could interesting, perhaps setting a deliberate error up on one pin and correcting via the other, or perhaps some Opto scheme.
But I think with 0.1mv untrimmed we won't bother today.
It's Tea Time -- and not a moment too soon
- Chip Amps
- Another DC servo question.
