another chip headamp
a test job.
I hook up 3 single channel opamps to directly drive left, right, and ground channels, a la PPA. The initial design uses LM6171 opamps,It is a better choice for this configuration.the 3 access gain setting in 5,and including 10pf slow down caps in feed back loops of each chips.+18v power supply.all hook wire is pc cables,such as SCSI interlink cable.
