Another "can I use this transformer?" thread
I just realized that the PCB has markings on the mains.
Blue 0v
Brown 110v
Orange 240v
White 220v
Red 127v
So I'm guessing it is a multi-tap. I'll make a dim bulb tester and see what I get.
Thanks guys.
did you test with the leads disconnected to the board? if that is the case then the primary is easy, just use the blue and the orange wire and you're done...
Ex-Moderator R.I.P.
Joined 2005
ok, before cutting I measured 450ohm at 240V mains switch
after cutting the blue wire from selector, still measure 450ohm
and 220V is gone from selector
seem fine so far
