HpW is proud to announce the new version 3.0 of the unique
FFT-based analysis software HpW Works. The new release includes an
improved lookout and several new display options, like Real Time FFT,
THD, THD+N, Dynamic range (DR), SNR and level calculations, phase view,
min/max band view, which can be displayed on each FFT. The analysis
data showing more detailed information is presented on a separate
data window. Using dual channels, the phase relationship is also shown.
Analyzing signals, in the labor, development or music studio is the
target use of HpW Works. HpW delivers high-end measurement for an
astonishing low price. The full system includes a FFT-software plus
signal generator, operating with any PC sound card or digital I/O hardware.
For the input and output section various add-on modules are available:
- MS Windows MMS wave devices :
Stereo 16/20/24 bit, mono dual speed
and special mono using stereo channels (20,24,28,32 bit),
- Text files (ASCII : integer or float)
- Wave files (16 / 24 / 32 bit and float type 3).
The FFT analyzer uses 64 bit resolution internally and supports up to
16 million sample points.
The wave generator delivers various signals:
sine (coherent / non-coherent), various harmonic's (1-64),
multi waves (1-512), static signal (DC), IM signals,
jitter test signal (fs/4 or fs/8 with LSB toggle),
test sequences and various noise signals. Additional any wave file
sequence can be loaded into the generator and played in an infinite
loop. Several global options like dither, channel muting and inverting
are also available (Stereo 16/20/24 bit, mono dual speed
and special mono using stereo channels (20,24,28,32 bit)).
What is new on V3.0 compared to V2.x:
Application:
o A single HTML Help file with HpW-Works 32 Bit content, FAQ and Glossary
o SMP CPU usage with multi threading implementation
o SDI Main & Client Window implementation
o Each HpW-Works client SDI Window may dock and stay attached to the main
application window
o Dynamically loaded Measurement Instance frame work
o Various user selectable themed colors for all HpW-Works dock and tool bars
o Preset applications with export and import (exchange) to file functions
o Maximum sample size increased to 16,777,216 (2^24)
o Uninstallation using the MS Windows system "Control Panel \ Add remove
Software"
o Configuration store in the MS Windows registry
o Common application folder setup dialog
o Common file dump setup dialog
o Common file dump tree setup dialog
o Use of a common "ProgramData" folder for file read & write operation
(ProgramData\HpW-Software\HpW-Works)
o Application protection using a personal USB data stick (no additional MS
Windows driver required)
o Separated installation kit for the HpW-Works Full Version and the HpW
Works Evaluation Version
Sound Card Source:
o Sample rate and interface capability check dialog
o Enable optional MS Windows WDM interface
Amplitude Window:
o New Amplitude Window with a sizable floating RMS toolbar
o Configurable statistic data options
o RMS Logger Window
FFT 2D Window:
o FFT phase view with optional level masking options
o FFT with min/max spectrum history shown as band or line
o FFT spectrum data export & import with owner watermarking
o FFT header text for each channel
o FFT with custom X axis range on X-Linear / X- Logarithmic / X-Center
o Full X/Y axis or only X axis mouse drag zooming on linear / logarithm
scale
o Re-Run FFT calculation with current sampled data
o New high performance FFT windowing functions with up to 13 terms
o SHIFT-Key or ALT-Key and spectrum dragging allows measuring X/Y axis data
Wave Generator:
o Enable optional the MS Windows WDM interface
o Auto restart option after closing any setup dialog
o Sine wave generation with phase option
o Sine & Harmonic with up to 64 individual harmonics (level & phase)
o Sine & Harmonic with export and import (exchange) functions
o Multi Sine Waves with up to 512 individual sine waves (frequency & level &
phase)
o Multi Sine with export and import (exchange) functions
System requirements: Windows XP, Vista, Windows 7, Sound Card
Internet: HpW-Works to get the evaluation version
Application:
application window
Software"
Sound Card Source:
Amplitude Window:
o RMS Logger Window
FFT 2D Window:
scale
Wave Generator:
phase)
ANN: HpW Works V3.2 PC based Measurement System
Version 3.2.0.x (Release date: 21-Oct-2012)
Supported MS Windows versions:
- MS Windows XP, 32 bit & 64 bit with WoW64 mode enabled
- MS Windows Vista, 32 & 64 bit with WoW64 mode enabled
- MS Windows 7, 32 & 64 bit with WoW64 mode enabled
- MS Windows 8, 32 & 64 bit with WoW64 mode enabled
New in this release:
- Help: A "Beginner's Guide" book
- Various tutorials
- Input Amplitude / level / impedance / dBSPL / external gain calibration
- Amplitude meter with additional dBV, dBmV, dBuV, dBu, dBW, dBmW, dBuW, dBc, dBSPL, Volt, Watt, % FS levels
- FFT Level Spectrum with additional dBV, dBmV, dBuV, dBu, dBc, dBSPL Y-axis scaling
- Power Spectrum (PSP) with dBFS, dBW, dBmW, dBuW, dBV^2, dBu, dBc Y-axis scaling
- Power Density Spectrum (PSD) with dBFS, dBV^2, dBc Y-axis scaling
- FFT / PSP / PSD with cursor x/y position toolbar (right click to alter between "spectrum data" or "grid position")
- Cursor data toolbar: Spectrum data or grid position related (right click on toolar to alter)
- Main Form: Memory channel count on status bar
- Description frame, color or transparent mode
- High performance flat top FFT Windows functions (HFT70, HFT95, HFT90D, HFT116D, HFT144D, HFT169D, HFT196D, HFT223D, HFT248D)
- Wave file & Text file rewind toolbar button
- Wave file extensible format support
- Wave Generator: New Jitter with symmetric J-Test signal (J. Dunn)
- Wave Generator: New IM SMPTE & DIN waves
- Wave Generator: New HpW-Works ".hpw" wave file extension introduced. Special stimulus files for the "Wave File Sequence" with automatic configuration
- Various tutorials
ANN: HpW Works V3.3 PC based Measurement System
- Input Amplitude calibration wizard alike setup dialog
- FFT Level Spectrum with additional dB/rtHz, Linear, Linear/rtHz Y-axis scaling
- Power Spectrum (PSP) with additional dB/Hz, Linear, Linear/Hz Y-axis scaling
ANN: HpW Works V3.4.1 PC based Measurement System
- Clear font drawing option
- Redesign (1) of Toolbars: New buttons and popup menu's.
- WASAPI PNP device list changed: Popup of a modal form with a related busy message
- WASAPI support with only input or output device channels
Feel free to download the latest evaluation version.
Hp
Hp
ANN: HpW Works V3.5 PC based Measurement System
- Added Fast Frequency Response Test Bench (FFR)
- Added spectrum bin detectors (RMS, Geometric Average, Average)
- Application redesign (2) towards MS Windows 10 and seamless operation
- Shortcut customization for must used actions
- Custom color palette & color picking
- Spectrum display layer with custom display order
- Crest factor calculation
- Spectrum smoothing line
- ASIO with 2x,4x,8x channel bundling
- Spectrum Average & THD analysis sequence changed
- Channel view toggle
- Individual channel freeze
- Fixes applied
Hp
- Fixes applied
Hp
ANN: HpW Works V3.6 PC based Measurement System
- Startup behavior improved and if any, showing a collected list of messages
- Preset settings simplified
- Data Store preset dependent auto load of stored items
- FFR Frequency response correction using data store item(s) with up to 6 individual items
- FFR Chevron locating symbol if result data spectrum is not on current grid scale
- All Test Bench with spectrum line width
- FFT/PSP/PSD Spectrum Math & Analysis BW & Weighting functions
- FFT/PSP/PSD Show optional filter spectrum
- FFT/PSP/PSD Spectrum difference view against first data store item
- RIAA and Inverse-RIAA spectrum math
- FFT & PSP small to large RBW settings for LDO & THD + N measurement
- Window 10 & release Windows 10 1511/1607 support
- Fixes applied
Hp
- Fixes applied
Hp
ANN: HpW Works V3.7 PC based Measurement System
- Changed: Y data scroll up/down (now as scroll arrows)
- Enhanced: Acquisition and interface mode change
- Enhanced: Data Store handling
- New: WASAPI Option, SR is controlled by other GUI
- Fixes applied
Hp
- Fixes applied
Hp
V3.8.0 HpW-Works 32 Bit release
V3.8.0 HpW-Works 32 Bit release:
- Changed FFT/PSP Analysis calculation to support higher SNR range
- Changed FFT/PSP Analysis 1. Harmonic reference changed from RMS to fundamental level
- Changed FFT/PSP Analysis Analog RBW mode and RBW Bin usage: RBW Bins used by DC and harmonics 2..n
- DSP spectrum subtraction math issue fixed
- Generator height fixed if hiding all toolbars
- Preset clone removed
- Menu Options / Preset: New "Preset Backup" entry
- Vendor's Bazaar
- ANN: HpW Works V3.0 PC based Measurement System
