Tobbe_L said:pjotr: "V" (capital) should never be used for velocity, the correct notation is "v".
Indeed it should be lower case, thanks
There are too many variables and not enough letters (romantic languages plus Greek). Early on, Maybe we should have adapted a system similar to Chinese where there are thousands of characters to know!
Seriously though:
Or even better: just use "x dot" in the Newtonian schema (dots on top of variables denote derivative w/r/t time). I think he actually made pin***** holes in paper for it !
x' (prime) = v, x'' = v' = a.
I just did all this in Physics (school's out w000t! ) so lemme see.
E (vector) = -dV/dx. V = potential, say you have 100V between two plates seperated 1m, the E field is 100V/m and pointed towards the negative plate. Likewise, V = integral E dot dx.
If anyone cares, the E-field at a point P is given by Q R(hat) /(4*pi*Eo*r^2) where R(hat) is the direction of r(vector), Q is charge in coulombs and Eo is epsilon naught, permitivity of space. You can do all sorts of integrals to evaluate the E-field due to various shapes of charges (using dQ).
Oh yeah, we were talking about symbols. W is used a lot. You have W (work = F * x (vectors, force dot distance) in joules), W (weight = m*g*y in newtons), W for watts (force dot velocity or work dot distance), all kinds of stuff. K's are always used a lot.
For electronics, we use V for volts, E for field, I, R, etc. U is potential energy, -deltaW (a work W). Like the potential energy of a gravitational system (U = m*g*deltaY) or an electric one (F = q1*q2*R(hat)/4*pi*Eo*r^2, aka coulomb force, evaluated over some distance to make that force an energy (W=f*d) and thus energy potential difference).
Tim
Tim
