An idea! Fully balanced TDA1541A DAC idea. Please comment!
Hi Guys!
I have an idea to make a fully balanced TDA1541A DAC.
It could works?
Thx!
Thanks Tazz for the comment...
...but I really don't see why better the Pedja's method?
Maybe the channel separation is better, but at my idea, the RCA and XLR outputs are simply to operate.
What do you think?
Why isn't good this method than Pedja's?
the way the 1541 is built, the AC current going to the supply pin is the same as the current in both outputs
so if you have a classical L/R implementation, it's just 2 separate channels
on the other hand, if you have L+/L-, the AC supply current becomes (L-)+(L+) so L-L=0
you get only (or almost) a DC supply current to the chip, making the regulation, decoupling, PSSR, problems almost disappear
