Amp Camp Amp - ACA
ACA is not good headphone amplifier because it INVERTS the phase. With speakers it is easy fix - you just swap the speaker leads, but with most headphones it is impossible to swap leads.
If you have a balanced out on your preamp you could drive input to ACA from (-) pin and ground. In this case two wrongs do make a right! I used this technique to drive mine and it sounds great on headphones. I put a 100 ohm resistor between the true output of the ACA and the headphone jack. This is an old trick I learned from 1960 vintage amp designs. Because the signal is inverted twice it comes out correct absolute phase from the ACA.
headphones are , besides most frequent place for short circuit (between them ), nothing else than (small) loudspeakers
I still didn't heard of any ldsp where you can't swap leads , if you need phase change
Ofcourse you can swap leads with headphones too, but with lots of headphones it does mean dissasemble them and make your headphone own cable. There are much better amplifiers for headphones then ACA.
Noise from fan
oI have ACA with small heatsink, so I used fan to cool it down. I am using LM317 regulator to lower voltage for fan and also to make the fan voltage adjustable. Problem is I can hear electrical noise from speakers when fan is running. I made two seperate ground points - one for ACA and one for fan PSU. The noise is now little less, but still audible.
The new version that is now available for sale should have this fixed :)
Is it possible to buy the ACA chassis separately with switch, rcas, powersupply jack, keratherm pads and mounting hardware. They are the perfect size for headphone amps and I have a ton of designs I would like to build using this chassis.
PS. I also love the big washers to spread the load on the mosfet. I'd buy a stack of them if you sold them separately.
Switches things on and off again
Joined 2000
Not at the moment but in about 2 weeks when we re-launch the store, we'll have ACA and all kinds of Hifi2000 chassis available.
diyAudio Editor
Joined 2001
Judging an amp from one example you built doesn't seem a perfect test. Maybe you made a mistake. Others seem to enjoy it a lot, I do. Of course I like the F-5 very much also, but their sounds are from different camps.- single-ended and low power vs. complementary. The ACA is pretty sensitive to what speakers it's used with, full-range seem to work best. Mark Fenlon of MarkAudio raved about it, but of course he makes full range drivers.
