http://cgi.ebay.com/1-Matched-Pairs...ryZ73372QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I would say you are quite lucky
So at 115db efficiency, i can run these off of a sonic impact amp? i can be sure to never blow them that way at least!
Now i have a problem though, I am thinking two horns with two dayton rs hifi subwoofers crossed at 500hz. The subs sound great, but i only have one... How much money am i willing to put into a sound system!?
these altec horns are quite large. I was wondering if i could biuld new horns with them that would sound better, and be smaller. Or, is what i have the best i can easily achieve?
The horns came with the drivers and are rated to 500hz:
http://i10.ebayimg.com/01/i/05/63/e7/1d_3.JPG
Yes you can build new horns but those are just fine. Those appear to be the 805's. What you might want to do is to damp the outside with either putty or a combination of latex paint and sand. This will reduce the ringing considerably. If not, the offer's still there for free disposal. How many of them do you have?
Hmm, your interest is certainly persuading me to get rid of them...
Yes, i certainly do not want to worry about coating them, too much work. I have five horns and drivers. Most of the horns were damaged when they were thrown away, but mostly just dented. Nothing a hammer cannot straighten out. I think i am going to sell one of the drivers and horns to fund the rest of the system. Maybe a BLH for under 500hz. Ill probably biamp the system and use a little tube amp for the horns. Do you think i will need a tweeter, or rather woud you?
tade said:I have five horns and drivers. Most of the horns were damaged when they were thrown away, but mostly just dented. Nothing a hammer cannot straighten out. I think i am going to sell one of the drivers and horns to fund the rest of the system.
Five horns & drivers? Dude, two words: Home Theatre.
How low can i get with these horns? They are rated to 500hz. I found this schematic for a crossover at three hundred hz:
http://sound.westhost.com/project09.htm
Perhaps one of you could help me convert that to one of 500hz? Or can i leave it at three hundred? I suppose that would help push the crossover out of the vocal band. I will also need a positive and negative supply for any electronic crossover? i will also need a way to match the sensitivity. i did so the other day with a 100 ohm resister in series with the horn. very impressive that it took that much to get the horn close to that of the woofer!
thanks for the help!
By the way i had one hooked up to a crossover at 100hz and a dayton rs 12". Probably not good for it, but the 1812 overture has given me a new boost of motivation. I like these horns!
- altec lansing 288c drivers
