Hi Jose,
I think you might want to ask over here in the Altec Forum.
http://www.hostboard.com/cgi-bin/ultimatebb.cgi/ubb/forum/f/3729
Hello...
Second try.... so if a partial post shows up.... I apologize in advance....
Anyway.... As I thought I was saying.... the 605 can work well in an OB format... it has a higher Q woofer.... so less roll off than most of the 604 family...including the E. And you can get out of the woofer sooner when using a phase correct crossover approach.... see here:
http://home.earthlink.net/~jmarkwart/index.html
Some really great info at Jeff's site... I did use a similar crossover with some mods to work with my LSAF OB project in May.... some comments here:
http://www.dagogo.com/Events/2008LSAF.html
Anyway... the 05 in my opinion is better suited... I have had E's and also still have some 604-8K's... and for OB I prefer the 05.... not quite as dynamic... and the old faux sectorial horn does not reach up as high as the CD horn on the 8K... but to me it sounds more musical.... my $0.02 worth.
Best..
John
Best..
John
an open baffle with quad tube ampl
hello
i have an open baffle l.s. altec 605 , on the top i am using horn super tweeter pioneer pt 410-f the baffle size
100x90x2.5 cm . th l.s. work s with 2 mono block tubes ampl quad classic (15wx2) and its sound very good.
i need some ideas (1) to improve the bass(2) mathing preamp like quad solid state or only tubes preamp like conard -johnson pv-10l(700$)...
some ieads about xover*
thanks a lot ezra
hello
thanks a lot ezra
