Pretty much you take the existing circuit and scale the power supply
up and parallel more output devices. Some resistors which feed
current to control circuits need to be scaled up in value or at least
examined for dissipation issues.
This works as long as you don't exceed the operating voltages of
the transistors and as long as they are cooled adequately.
Nelson Pass said:Pretty much you take the existing circuit and scale the power supply
thanks for info....i need the Aleph X, 100watts circuit diagram.
thanks for help
micahel
Search is your friend here:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=8933&highlight=
-David
-David
