I did not look at the specs of the caps beyond voltage, capacitance and sizes.
However, they are from well-established companies so general quality should not be
a problem. However, you may want to look at the spec sheets from the
manufacturers to confirm.
I did not look exhaustively at Mouser to find all choices, instead just picking a
a few that should fit as-is. Also the filtering on mouser is not quite accurate
as not all dimension parameters are in the system, so there are likely many
more suitable caps available.
