Aleph J Schematic
no, I use the second version of the schematic above with 6sl7 as amplifier stage and 6sn7 as buffer, with a separate casing psu
Official Court Jester
Joined 2003
with 6SL7 you're having way too much gain
not exactly most clever solution , looking from signal leveling point of view - too much attenuating and then too much amplifying
with funny J , all you need is gain of 2-3x , at least I prefer stages like that to purely passive
I also like iterations with just proper buffering , so no gain at all
Joined 2003
Yes
Being difficult?:D
I actually use beautiful triode 6v6. Waiting for, not really, SUsy 6V6, althought that just might counteract loveliness of triode.
send me exact schematic you're using now , and I'll give you what you want
you know that it will be bal in bal out , and that will inevitably kill some of second harmonic sweetness
you can gain some of it back , but not entirely
it will help if you give me voltages here and there ( and gain figure , too ), to save me too much looking at graphs
then say what gain figure you want
those things are easypeasy ; what is not easypeasy is when you want DC coupling all the way
I may when time comes. Too far in the hole to worry about now. I may not do it and just keep it as part of SE rig. It is the killing of the sweetness that I am not excited about, as that is the reason for it in the first place.
I do have question. I think 6v6 pre has about 15dB of gain. I should only need 10 more, max for Altec rig, correct.
Joined 2007
r27 as a pot to jack up the bias. more bias makes it sound better. but adds heat.
OK! My plain A-J boards check out, which is a relief! I tested a SE signal into each side of each board using a junk speaker and first impressions are favorable. One side measured 8.73 V across R8 rather than 8.3... That board seems to have a bit more gain and a little less control than the one that measures 8.3... Thoughts?
So, I'm planning to remove R27 and install multi-turn trimmer pots. Question: does increasing the resistance at R27 increase or decrease the bias? :eek:
TIA,
Frank
Joined 2007
Answer to my own question: I don't have much thermal headroom to raise the bias anyway, so the R27 pots are sitting at 64k. With that amount of current, the temperature rise is ~32 degrees above ambient with silent airflow, 27 degrees with the fan 'barely noticeable', and 24-25 degrees with the fan at full speed of 1200rpm. If you are curious, images are the air tunnel, the front panel fan control with thermal readout, and the profile of the air exhaust. The power supplies have 75 degree thermal cutoff switches on the heatsinks.
Frank
