I did exactly the same changing from an F5 to the J and mine is the same but it is only a relatively gentle thump.
Nelson says in the manual that " switch on /off noise is gentle in this amp " although how that equates to actual noise level...?
It will be interesting to see if removing the 2k2 resistor helps.
Before I start cutting my resistors , here is a movie of the thump:
I switch off with a rockerswitch at six seconds. Also hear the "craaahhh" sound...
MVI 5123 - YouTube
Walter
MVI 5123 - YouTube
Walter
22Vac is in ballpark , really ; no need for wasting time for analysis
only if you're interested in higher voltages .......... in that case just search for various amps from Aleph series , and imagine each of them with Jfet FE (cascoded where needed , due to higher PSU voltages)
What are the pros and cons of lower and higher voltages?
I do ask cos PSU design (CLC vs CRCLC with several R values) does affect DC voltage.
Better filtering (resulting in +-22.5 V) vs higher voltage (say +-24 V)? I was just playing
with PSI designer.
Hi ZM, here are the voltages... left and right measure identical. Everything is measured against ground.
PSU is between 24.0 and 24.2 volts. Bias is 0,38 volts over 0.47 Ohm. meausured with a warm 49C amp.
Maybe the thump is high because of the current limiter I left out?
Thanks, Walter
Thanks, Walter
Thanks, Walter
there is just one way to solve a dilemma ....... put it in
even if I think that culprit is exactly there .....
Hi
I just want to get some feedback. Are there any issues on the BOM that needs attention? Are those that used it happy?
I made a comment way back here...
http://www.diyaudio.com/forums/pass-labs/224881-aleph-j-universal-mounting-spec-42.html#post3579550
Ignored!
I understand now why I can use 22V AC: with + and - 24V PSU I have 20V over the JFets, so with 30 Volts PSU around 25V, which is the official max for 2SJ108 / 74. Dissipation will be exactly the 200mW for the small JFet
Q1b ?
you still can ....... but correct that logic
Confirm: the fact that R5 dissipates 300mW, and that R5 should be specced as 1/2 Watt resistor?
I myself used an RN60D there, which is Mil-Spec 1/4 Watt, but is really a 1/2 Watt resistor (basically same as CMF60). If we get consensus I can change the BOM.
- Aleph J for Universal Mounting Spec
