OK, I just need some advice with the LEDs. There are thousands to select from, so some help just to nudge me in some direction would help. Obviously Blue will be favoured by most.
Not too worry, I will use http://za.mouser.com/Search/ProductDetail.aspx?R=C566C-BFN-CS0W0352virtualkey57280000virtualkey941-C566CBFNCS0W0352
Actually, as the LED are there to show proper power to the amp PCB, you will want 2 different colors. Red and Green are the most logical, to show V+ and V-
But some people will want to use at least one of those LED as a 'power on' indicator... So whatever you might find in the way of Pass blue is cool as well...
I think its best just to stick to original numbers. I am sure anything can be tweaked to perfection, but this should happen on individual basis, as all folks builds will be different.
Initial prigin for matched quad will be $12. If using dual output pairs, as I suggest, then $24.
henryve -- Thanks so much for your work on this! The BOM and notes will be extremely helpful to everybody wanting to build this amp.
As for buzzforb's suggestion of attaching a schematic, I think that's a great idea, it's just that there isn't a really good one yet - the original schematic dosen't have any of the changes, and the eagle schematic that didiet used for making the PCB has a bunch of extraneous bits to facilitate the PCB drilling and pads...
Once we have the PCB tested I will make sure there is an "official" schematic for this. In the time being, didiet's is best.
Question - does anybody know what software Nelson uses for his schematics? Visually it's very appealing, I would love to have the final schematic drawn in that...
- Aleph J for Universal Mounting Spec
