Hello,
I have a DIY Aleph 3 and I am happy. A friend doubts among building an Aleph 3 or an Aleph-X, me known not to respond him.
That you differ do they exist in listens to it?
That power gives this circuit?
http://web.vip.hr/pcb-design.vip/alephx.html
Ángel
Ángel
Angel,
building the X is a bit more difficult tham building the aleph 3 but I think it is worth it.
There are a few descriptions of the difference in sound between X and Alephon the forum. Here are two I found but there must be more:
http://www.diyaudio.com/forums/showthread.php?postid=591051#post591051
http://www.diyaudio.com/forums/showthread.php?postid=645248#post645248
William
William
in fact all of the things that must be watched (concerning power into different loads) when building an Aleph also have to be watched when building an X.
In both you can set 3 things:
1. Power Supply Voltage
2. Bias
3. Ac-Current-Gain
With these you can make everything you want (as long as your heatsinks are big enough). For the same power output even the dissipation will be equal between X and Aleph.
William
2. Bias
3. Ac-Current-Gain
William
Hello,
For an universal amplifier of about 60w - 70 w in class TO my the suggestion that I gave him was:
I built a friend and it manages any speaker very well. You go on sure.
http://www.borbelyaudio.com/eb2000342.asp
Ángel
Ángel
I'm always amused and amazed by how these rumors get started. Either the Aleph or the Aleph-X will do just fine with low-Z loads, assuming sufficient bias.
When I first started the original thread on the Mini-A, just about the first thing people asked was whether it would handle a 4 ohm load. In that case, no, I had not provided enough bias for 4 ohms, although increasing the bias is a pretty simple operation. So when I did the Aleph-X I made sure to boost the current so that it would (almost) handle 4 ohms. If you want more bias still, have at it. Just make sure that you have a robust power supply.
Grey
Grey
i was just speculating, thats all...
as i recall (which could be incorrect), you can make an alephx that can be well suited for 4 ohm loads, but it would be HIGHLY inefficient and produce massive amounts of heat and have a very robust power supply. i just remember its better suited with 8 ohm loads.
just about any amp can be customized to work at different load ratings, some are just more suited for different applications.
im glad you are amused.
Any amp biased heavily enough for a low-Z load is going to be less efficient, regardless of topology, gain devices, etc. The lower the load impedance, the higher the bias required, and the greater the heat generated at idle. If it's not used to produce sound, it goes up as heat, making the amp inefficient. You can't beat physics. All you can do is back off and go class AB or D or something, but then you're changing the rules of the game.
Grey
Grey
- Aleph 3 , Alehp-X
