Scan and Email? If you are happy to do this I will give you my EMail address.
As a separate issue, I am just populating my Aleph 2 boards and on the main board there is a connection for an LED. Is this the indicator LED on the front panel, or is an LED used as a diode in the circuit? Your advice would be much appreciated.
hifileslie said:Scan and Email? If you are happy to do this I will give you my EMail address.
You will have to do so, as you have blocked emails from members.
Hi!
My I have too the A2 service manual?
I am thinking getting a pair (I miss my Aleph 3 and Aleph 30, gone time ago...).
With all the heat inside, what can one expect to find relative to caps status? Are replacement easy to find or one has to 'invent' a little bit? (maybe taking advantage, doing a 'many small caps' plus RC filtering?
Thanks!
Josep
Thanks!
Josep
Yo_Azazel said:Damn... I am not allowed to send PMs.
See if you (Zen Mod) can send it to my email: joseparmeng (ad) gmail (dot) com
Thanks again guys.
A2srv0.pdf sent to your addy
- ALEPH 2 Service Manual
