Akai AA-6100
This should be fun.
Top of uncles closet, tucked away. And still works!!
Time for upgrades. And cleaning.
Its a pretty audible white noise, probably from the gain. Unless turned all the way up, to there there is no resistance.
I just leave the volume all the way up to avoid the noise and use the source to control volume.
I would like to find a way to bypass the bass and treble Eq. And run this little amp as a straight forward amp.
http://www.hifiengine.com/manual_library/akai/aa-6100.shtml
There's the schematic. Find the power stage input trace and solder a shielded wire from those to rca jacks. But don't do anything that can't be reversed.
