Aiwa CDC-MP32 Headunit Unresponsive
Hi, got this older flip headunit that isn't fully working that I'm not really sure what the problem is.
Display turns on and lights up, however no text or anything appears, all buttons are unresponsive (besides reset button) and the display does not flip as it should (second image).
Reset button moves the flip mechanism gears very little that you can hear it and see it (only after looking inside) 1-2 seconds after pressing. The display will not move when this happens (besides very slightly that it is easy to miss as if it tries to move).
Tried putting standard 12v to it, and the recommended 14.4v, same result.
When it turns on you can hear it start to read a CD that is inside of the CD slot then stops.
Only thing I saw when I opened it up is these groups of caps covered in something although I think it may just be flux (this is under the cd player)
I have a pretty strong feeling that is flux then, there is almost no smell, and it board does not seem to be damaged
It cracks like flux normally does when moved and it looks a lot like flux
Highlighted pins are which showed positive DC
Blue showed 2 rails, ground and positive DC
I believe I accidentally shorted 2 pins which caused that smell and for the headunit to reset as I shorted it, whoops 😬
After letting it sit for a bit and restarting smell went away and did the same as it had and that's when i checked the pins
This is what the blue showed
I don't have a thermal imager but I have canned air
The IC doesn't heat up while idling
I don't remember what I did but something I did managed to get the headunit to cycle through the display flip and back, which tells me that the motor and gears are working, but still does the same as before on
initial powerup and when I hit the reset button
Not that I can see, though one half of both orange ones are hidden
Just a flip face but can be taken apart by disassembly, should I try and take it off?
I thought so as well but it wasn’t, it was pretty weird but this is what it shows now, voltage increases when reset button is pressed so I think it has something to do with reset
