EL34†Î¶ËºÏŽÕ·Å´óÆ÷£¨È«ÊÖ¹¤Åﺸ£©
Ý”³ö¹¦ÂÊ2*12W îl‡»20HZ¡ª-35KHZ
ì`Ãô¶È2V ʧÕæ¶È25WʱСÓÚ0.5%
ÐÅÔë±È90dB Õû»úÖØÁ¿20KG
Ý”Èë×迹98K Ý”³ö×迹4Å·/8Å·
ÍâÐγߴç42*39*20£¨Œˆ*Éî*¸ß£©£¨CM£©
Õæ¿Õ¹Ü£ºEL34*2Åä¶Ô£¬12AU7*2Åä¶Ô £¬5AR4Êï¹â¶Ô
ëŠÔ´Å££º350W*1 Ý”³öÅ£18W*2 ¶óÁ÷Ȧ£º5H0.5MA
RMB:2800
£¨AIKESI)“ÀMëŠÔ’£º86+13977459851 £¨chenchen2008@yeah.net £©
RMB:2800
Aikesi Ù_ machine el34 seeks the overseas proxy, may deliver one!!
The EL34 single end gathers ŽÕ the amplifier (the entire hand work shed welds)
the output 2*12W frequency to 20HZ--35KHZ
sensitivity 2V when degree of distortion 25W is smaller than 0.5%
signal-to-noise ratio 90dB complete machine weight 20KG
input impedance 98K output impedance 4 ohm /8 ohm
external dimensions 42*39*20 (Œˆ * deeply * high) the (CM)
vacuum tube: EL34*2 pair, 12AU7*2 pair, 5AR4 dawn to
power source cow: 350W*1 loses drives oxen to the fields to work the 18W*2 impedance coil: 5H0.5MA
RMB:2800
(AIKESI) telephone: 86+13977459851
RMB:2800
