Aftermarket ac power cable-put your opinions here too :-)
Bare Naked Ladies???, some good tunes.
I wonder, that may be three separate cords of three conductor. They bought a 14awg extension cord from home depot, cut it into three lengths, then paralleled all the greens, all the blacks, and all the whites.
And, because that cord had thick wire insulation, the characteristic impedance of the cable is about 200 ohms...divided by three, 66.6 ohms.
Then, make it 10 feet long, so the characteristic impedance-length product is 666.
Mark of the devil...that's a baaaad cord, nuttin good can come of it..
Jn
Many people have found thru listening, that Ferromagnetic material like ferrite clamps and rings sound bad. They affect the sound in a bad way. I believe it says this in the patent. Forum member Charles Hansen (RIP) talked about how ferrite should be kept away from audio equipment. But Ferroelectric material does not have this problem, that is one of the reasons Shunyata uses it.
While what in fact probably happened was:
Correctly chosen and placed ferrites can reduce noise/interference, but some audiophiles enjoy the added background noise (it seems to add definition or sparkle). So they are less happy with the more accurate (less interference) sound.
