Aethers: budget OB from Iowa 2007
Re: dipole roll-off ~ baffle size
otto88 said:
Hi
“When I was first designing the Aethers, I was told by very reputable sources that dipole roll-off would be an issue around 150-200 Hz”
I’m having trouble reading the cut sheet 100%. Is the open baffle 18 in * 9 in?
Well, that piece is 18x9, but then I attached 4.75" wings to the side, making it a "u-frame" enclosure. This means the front baffle is actually 10.5" wide, altogether. Does that make sense?
Andy has a good point about making the u-frame section 20" tall. There's no problem with that. Just be sure to keep the tweeter near your seated ear level.
-Paul
