Hello.
I just bought a Peter Daniel LM3875 Classic kit, and a SKA-Volumebuffer, I want to build an intergrated amp with DAC and RIAA, and need some advice on how to do this. I am thinking a USB powered DAC of sorts (open for suggestions), like perhaps a small and simple Bantam or the likes. and a SKA-RIAA, mostly because this is a very affordable solution, and looks doable for someone with my limited experience. Can I power both the RIAA and amp with the same toroid, or do I need two? Suggestions for a not too expensive selector switch?
Could the LM3875 chips be mounted on the sidepanels og the GX383 chassis?
MO, Please visit and join the MyRef integrated thread. Hopefully you can both find and add some ideas on this kind of build.
http://www.diyaudio.com/forums/chip-amps/203666-myref-integrated-solutions.html#post2843940
The focus there is on the MyRef but the thread is not limited to that amp.
Additionally, I bought one of these several months ago. It has surprisingly good sound though I wouldn't call it top of the audiophile category. On-board power amp can easily be bypassed. FM is a plus.
MP3 hardware decoder+Remote control unite | eBay
Hi Andrew,
When I bought that unit I was looking for a simple way to get audio files into an LDR/MyRef combination. As I prefer uncompressed (Flac and Apple Lossless) sources and this piece doesn't yet have the ability to do that type of decoding, I did not go much further in considering it as an optimum match for the MyRef.
If one wanted to build a good quality mini or computer driven integrated system. this unit combines multiple input types, a very listenable DAC, a pre, an output amp and a FM tuner on a super small footprint (5 cm sq).
I tried both types of outputs, fed MP3 files from USB stick (with operable function buttons from 12 ft away) and used line in from a Sony Walkman. I did not try to feed it with a USB stream from a computer. I was able to receive a couple local FM stations without an antenna. The power amp drove two DIY speakers (W=3", TW=3/4", .5 CuFt ported) to a decent and usable SPL.
This could be a very good core for a fun and respectable sounding integrated. I would be happy to start a new thread if there is enough interest.
P.S. At least two suppliers have said they are working on adding the uncompressed file decoding.
- Chip Amps
- Advice on intergrated...
