I have a GFA-545 that has a left channel distortion LED lit. Channel sounds fine and the amp has been operating great. Still is. What could be the problem? Schematic attached with the LED in yellow.
Measure and compare the volt drop across R607 with the good channel. Also measure the voltage across R613 and compare with good channel. Should be around 0.68v ish.
