Adcom GCD-600 turning on (kind of) while powered off
My GCD-600 cd player works ok while turned on. But the problem comes when powered off…. After a few minutes of being off, it starts to click (relay click) and the display turns on dimly. The clicking is erratic In tempo. If you turnt it on, the unit goes back to normal and works as expected.
im attaching the service manual, hoping that someone can share some light into this issue. Most probably is a cap that has high resistance, heats up and shorts the circuit to ground, maybe.
Any insight will be highly appreciated.
cheers,
Luis
  • adcom_gcd-600_sm.pdf
