Active Inrush Current Limiter
Brute force approach?
400 amp Hexfred diodes. :D (they're small...)
ok, so you still need to limit the intial turn on current in most cases, but you won't blow the diodes if you have a stiff enough line to run the amp...
:rolleyes:
_-_-bear :Pawprint:
PS. I turn on ~500,000ufd in my big amp with a pair of relays that connect the Mains --> resistor --> then shunts the resistor with another big *** relay (multi- contact) run off a lowly 555. Dumb, simple & reliable.
Upupa Epops said:
Simply circuit is the best : serial resistor in primary, shorted after while by relay. Resistor must be wire wound ( classical " round "performance - not sqaure white ones ), 15 - 25 W, 33 R - 47 R, time delay cca 2 sec. With this values you can use it for transformers up to cca 1.5 kW.
What's wrong with the squared ones? I think they work pretty good also.
To peranders : By switch on is resistor of this value ( 33 R ) manytimes overloaded. Round ones have wire spiral around all body, while square ones have this spiral smaler and inside body, so short - time overload is by round ones bigger. I had try on this position both types and " white one " had lower reliability, belive me ;) .
janneman said:
Steven, would you agree that if you can control the switch-off as well, it's best to do it ar zero current to avoid any remanent magnetism, which could aggravate any switch-on surge?
Jan Didden
Hi Jan,
I would say: yes. The flux B is 90 degrees lagging wrt the applied primary voltage. If voltage is at maximum, the B is zero. This is importanty for both switch on and switch off. If switched off during zero crossing of the voltage a strong residual flux will remain, up to 80% of Bmax. If then switched on at the wrong zero voltage crossing, saturation will be even more severe. Worst case: switch off at negative zero voltage crossing, switch on at positive zero voltage crossing (or the other way around, i.e. the crossing in the opposite direction).
Switch off at zero current would be close to zero flux, although a loaded transformer will not be purely inductive.
Steven
This is correct - surface cooling area is considerably larger for the "round ones". The "squared ones" have smaller body encapsulated by ceramic housing and their peak current overload capacity is lower.
Steven said:
Hi Jan,
Steven
I can certainly confirm -- I set up the model to trigger the "ON" at the zero-crossing voltage and the current was such to set a fault condition, terminating the sim -- and worse at "OFF".
alvaius said:
there are a couple application notes which go with this part (which costs about $1.70 from DK here in the states) AN1600 and AN1602 on ST's website.
the STIL04-P5 requires an auxiliary supply -- like synchronous rectification
one thing which is interestingfrom AN1600 is that the EMI inductor filter is used to smooth the current into the bulk capacitor -- (this is also inrush current limiting!)
it's an interesting idea.
This is maybe true but I doubt that this fact really is important for a 0.3 sec pulse. Anyway I have used 4 or 5 Watts, 100 ohms starting 600 VA/2 x 22000 uF/+-60 V since 1989. The amp has been switched on almost everyday since that year. The only thing that have gone broken was my 470 ohms in series with the "big" cap. This resistor was a 0.6 W metall film. I have changed this to four 120 ohms in series.
Yes, this is correct, by 100 R value will be overload not so big. But look at DC voltage on caps during the process : probably serial resistor is shorted by relay in time, when DC voltage isn't full, so you get still relatively high inrush pulse. One example by my experience : two toroidal transformers 850 VA each, total capacity of PS 160 G / 80 V, serial resistor 40 Ohm / 50 W, delay of switching cca 1.5 sec. . Average " first " inrush current was cca 6 A ( measured on mains side by relatively " fast " pointer ampermeter ), " second " inrush current 6 - 8 A. Voltage on elyts was at the moment of switching cca 90 % of full voltage. In your case must be voltage lower, so you get higher " second " inrush and it is not good for reliability.
Here is example of this circuit, which I'm using many years. Delay is make by counter which count mains frequency, so delay is independent on tolerance of devices. Diodes at rectifier are 1N4002, other are 1N4148. All transistors are BC 546 or similar. Transformer is 3 VA, 15 V on secondary. On PCB are also mains fuses for two mains transformer. Circuit is connected between mains switch and transformers. Fuse 2A protect R 10 against long time overload ( by disorder of delay circuit or relay ).
  • softstart schema.pdf
Re: Unhappy Diode
jackinnj said:
I was experimenting with MBR20100's -- cycling the power supply -- this is the result (before choke installation):
not only did it blow the diode apart, it also blew the leg off the bleeder resistor.
If this was a normal condition, didn't you choose one size too small diode for the task?
