• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
AckoDAC based on AK4499EQ
Some influence of times, export version may look different 🤣
Stand-offs and risers not part of standard supply. The ones shown are nickel plated brass, so non- magnetic or other concerns? Just showing possibilities for any add-on modules later - perhaps for a tail kit:) End users can decide on material type for the fixtures. Can be suspended fixtures to reduce acoustic feedback if needed. Critical components like caps are film type so not much affected by vibrations. Clocks can be externally piped in.
Firmware development for the controller completed and loaded onto Controller. Marathon effort to effectively control two chips of this AKM dac, including dual mono mode. Early tests indicate successful ‘lock’ and some control functions working as intended - no audio feed yet. Next step, to confirm all registers set properly and then live tests:)
Reactions: 2 users
Testing… @DSD256
DAC needs +/-15V master supply (9-15V). On-board regs distribute to all different sections. Simplifies power supply arrangement. If preferred, on-board ones can be bypassed for choice of external supplies for just about every section e.g. batteries, ultra caps etc..
Reactions: 2 users
