Accidental MLTL Technique
I think that this design will bring a reduction of the treble, as a push-pull
is inherently mass-loaded :confused::rolleyes: No, maybe not !
But, yes, it will make some changement in something !
My latest idea for multiple drivers intended for just bass- because some
nasty interferences will occur as c-t-c spacing relating to the frequency and to the shape of the cone.......- is to make a triplet, each speaker placed at the extremes of an equilateral triangle :eek:
I'm just finishing my 'accidental MLTL' ....3 way....:cool:
Founder of XSA-Labs
Joined 2012
Pico,
I think Ryan was doing push-push not push-pull. What do you mean all push pulls are inherently mass loaded? Setting drivers as close together as possible should reduce comb interference and also only 2 on each side should minimize effect of reduced vertical dispersion of an array. Looking forward to seeing your AMLTL. Which drivers are you using?
X
So you'll need to make a drawing of your idea.
I did an isobaric push-pull 3-4 years ago, sort of FAST. I used some cheap
drivers such the Ciare HW 159. I dismantled them- well, just the internal wall- and I made a regular two way. So 2 HW 159 are sitting alone ....
In the meantime I found at the trash :dice::smash: 2 complete enclosures
It was a rainy day....So eventually I've got one of the most famous mid-domes
still from Ciare, and two 3-way crossovers. The tweeters, I'm using two Audax.
About the mass of air between two drivers in a push-pull...:confused:
Ehm...what do you think the mass is composed by ?
The cone is then loaded by the mass of air in the pipe
And this mass is moved up and down -it's coupled to the cone, but
till a certain frequency because it's a mass and have a certain inertia ( and viscosity, as it's a fluid ) . So at higher frequency it's not mass-loaded and
the cone it's free to vibrate ! :p;)
Given this assumption, the air in an isobaric ( equal-pressure ) push-pull
acts as mass loading the cone(s) because it has a certain weight.
It's also elastic, that's why I don't like isobaric no more.
Founder of XSA-Labs
Joined 2012
Pico,
Obviously air has mass and I am not saying that the cones don't have mass loading. It is a matter of terminology in speaker design and types of alignments. The term Mass Loaded Transmission Line refers to the analogy of loading mass on the end of a vibrating cantilever tuning fork to reduce its natural quarter wave resonant frequency. The tuning fork's resonant frequency is normally a function of its stiffness or Young's modulus and length. However, adding point masses to the tips of the fork tines will reduce the natural frequency. Somebody started calling the addition of a constriction in the mouth of the quarter wave aeroacoustic resonator "mass loading" so there we are, stuck with the term. I would have called it something like "constricted vent transmission line" but I did not get to name it. :)
Founder of XSA-Labs
Joined 2012
As Ryan is cutting plywood as we speak, I am for the first time cutting something other than foam core to make my next speaker: masonite board to make the baffle of a wall mount TABAQ like MLTL. It is a folded affair with overall 11.25 in wide x 17 in tall x 3.75 in deep. The csa is identical to the TABAQ at 20 square inches and length is 30.7 inches unfolded, vent is identical and will be a rectangular down firing slot. The driver will end up at one end and symmetric so that it can be used for either left or right channels. It will have foam core side walls and back panel and use Vifa driver. Since it will be wall mounted no BSC will be needed. So this is first time I needed anything besides a drill. I used jigsaw to cut the holes for the drivers.
I don't know much of the cantilever and fork tuning, luckyily you hadn't brought the aerial transmission line example with the antennas !
For what I know, my model works, as also the terminology with it.
With the TL and 1/4 wave models as example, what would change between:
closed TL or labyrinth, tapered; regular TL, straight or tapered (not considering the Voigt or expanding pipe); a TL with a duct at the terminus , which is the ML-TL. :confused::rolleyes:
Well here it is! A quick build on a snowy day.
I've had it playing for literally 5 min and WOW! Out in the garage I had it hooked up while stuffing it. No lid no bass response. Slowly slide the lid on and poof! amazing sound.
Bad thing is now I'm going to have to build another to match. haha
Here's a before and after shot. I'll be writing up a build thread later today with more pics.
X thanks for all your help! It's greatly appreciated. Thanks again!
