Not necessary be 19V exact...3A minimum (ACA will drain roughly 1A@5W, 1.5A@6W -with 2.2K R15),bigger the better...
Check out below newegg link, note they may not include power cord, which you need buy separately.
Computers & Tablets, All Laptop Accessories, Laptop Batteries / AC Adapters, AC Adapter - Newegg.com
What's your ACA input look like, similar to the diyaudio kit? Normally the size should be 5.5/2.5 or 5.5/2.1...if you know the DC inlet size, then you can buy the proper DC outlet and replace the ones on your PSU ...
something like this:
10pcs Male Electrical Socket Outlet DC 005 DC Outlet 5.5X2.1MM 5.5*2.1 -in Electrical Plugs & Sockets from Electrical Equipment & Supplies on Aliexpress.com | Alibaba Group
