A bit more info here:
http://www.ampchipdiy.com/phpBB2/viewtopic.php?t=112&sid=4b4cdc28f9872aea1e3139e53d6bcb5b
interesting
I noticed the discussion about HUM, it also states that even Peter heard some hum in high efficiency speakers.
I bought 5 (Abbott) transformers from Apexjr and one gives some hum through the system , the others do not have any noise. None of the Baslers has any hum, maybe the hum comes from some of the transformers, can that be?
I am going to try some other transformers next week.
by the way, the enclosure is definitely unique!
J-P
J-P
>> Where did you got idea for case?
The case is made from wood as I find it much easier to work with than metal. It is designed to have as small a footprint as possible (with no particular height restriction) and to be fairly efficient at keeping itself cool. The vents also allow glimpses of the valves.
I'm not familiar with SE amps (?) but the VBIGC sounds much richer and more velvety than my original non-buffered IGC. Have a look at the sites I mentioned before.
I like inspiration for case for new amplifer, probably make from wood as cheaper and more nice to look than metal. I like to ask you to make but peru is very very far from UK
Do you or anyone have other example of amp with very good case? I have seen some but not any so good....
Have you looked at the Gainclone gallery
HERE ?
- Chip Amps
- A Vbigc
