A Thread for those interested in PPSL enclosures
@ norman bates
Just for eg, i simmed the Fane COLOSSUS PRIME 15XS
FS 36.3 Hz
Qts 0.310
Vas 149.70 Litres
as follows
Box int vol = 150L - fb = 36.3Hz - Parametric EQ = +3dB @ 30Hz with Q = 2 - f3 = 32Hz - f9 = 27.2Hz
attachment.php
Agreed though, that usually low Qts = less low bass.
I'll take a stab.
6th order is where you put a driver in a ported box, tune to the f9, then run a high pass filter with a q of 2 at the tuning frequency. The filter does 2 things, it gives a 6db boost at tuning and acts as a subsonic filter below that. A qts around .32, you can tune to fs and box area smaller than a typical 4th order with qts .4 (usualy equal to vas).
Djk explains it better
https://www.audioasylum.com/messages/hug/127065/low-qts
thanks , that shed some light on my question re 6th order and helps me sim my drivers in winisd .
Any driver.
Ppsl can be ported, sealed, tl, or even linkwitz transform eq it flat to 8hz.
6th order is just another way to do a ported.
It works well for qts under say .35 because it gives you a small box, you use drivers with usually higher sensitivity, but you need 6db of boost at tuning. Otherwise, a qts .35 would have less low bass ported and especially sealed than a driver with qts .4, but a qts .4 ideally wants a ported box as big as its vas (big).
-3dB at 42hz (with filter)
Driver Properties
Type: Standard one-way driver
No. of Drivers = 2
Mounting = Standard
Wiring = Parallel
Fs = 50 Hz
Qms = 9.9
Vas = 79.2 liters
Cms = 0.233 mm/N
Mms = 43.45 g
Rms = 1.379 kg/s
Xmax = 4.92 mm
Xmech = 7.38 mm
P-Dia = 249.5 mm
Sd = 489 sq.cm
P-Vd = 0.241 liters
Qes = 0.37
Re = 5.4 ohms
Le = 0.42 mH
Z = 8 ohms
BL = 14.11 Tm
Pe = 300 watts
Qts = 0.357
no = 2.58 %
1-W SPL = 96.26 dB
2.83-V SPL = 97.97 dB
Box Properties
Name:
Type: Vented Box w/ Active HP Filter
Shape: Prism, square (optimum)
Vb = 3.3 cu.ft
Fb = 42 Hz
QL = 6.61
F3 = 42.1 Hz
Fill = minimal
No. of Vents = 3
Vent shape = round
Vent ends = one flush
Dv = 4 in
Lv = 12.89 in
in
Active 12 dB/oct. HP Filter
Fx = 42 Hz
Qx = 2
Using an amp bigger than 600W/4Ω will exceed x-max on program with sine-sweeps, probably not on real music.
Joined 2008
A quick question to those in the know.
Would these drivers FaitalPRO | LF Loudspeakers | 12PR300 work in a ppsl? I don't need to go too high, just 200hz down.
That is a fine choice of a driver for mid-bass applications. But, a "woofer" it is not. I am enjoying a cup of coffee and have a few minutes to spare, so I thought about JRKO's situation for a while. Assuming he wants twin 12's per side and decent bass, I thought I would look at what Parts Express has for their Dayton line of woofers. They also offer International shipping for our friends across the pond. I arrived at the Dayton Audio DS315-8. This driver fits into either a sealed enclosure, or a ported. A sealed gives you an F3 of 55Hz in a 1.4 EACH. A ported gets you down to 35Hz at the cost of 2.35 cubic foot for each driver, PLUS the plenum volume. This gets to be a large enclosure, so it would depend on JRKO's domestic situation. For me, I would choose the ported, and build the classic ppsl with the required (as large as you can fit) port along the bottom as per Les Hudson's basic design.
https://www.parts-express.com/dayton-audio-ds315-8-12-designer-series-woofer-speaker--295-434
Driver Properties
No. of Drivers = 2
Mounting = Standard
Wiring = Parallel
Fs = 46.17 Hz
Qms = 13.87
Vas = 126.4 liters
Cms = 0.108 mm/N
Mms = 110.1 g
Rms = 2.302 kg/s
Xmax = 8.2 mm
Xmech = 12.3 mm
P-Dia = 340 mm
Sd = 907.9 sq.cm
P-Vd = 0.744 liters
Qes = 0.3
Re = 6.59 ohms
Le = 0.78 mH
Z = 8 ohms
BL = 26.48 Tm
Pe = 600 watts
Qts = 0.294
no = 3.998 %
1-W SPL = 98.17 dB
2.83-V SPL = 99.01 dB
Box Properties
Name:
Vb = 5.25 cu.ft
Fb = 40 Hz
QL = 6.472
F3 = 39.99 Hz
Fill = minimal
No. of Vents = 2
Vent shape = other
Av = 36.93 sq.in
Lv = 16.49 in
Fx = 40 Hz
Qx = 2
Keeping the plenum as shallow as possible gives the highest bandwidth. A 16.5" (internal) deep plenum generally has a small peak in the 160hz~180hz range, followed by a small dip, and then falls off a cliff around 250hz or so. I have crossed as high as 250hz (without EQ) and got good results, generally to horn-loaded 12's.
I've never made them out of 15mm.
I made one pair out of 12mm/9ply BB. They sounded OK, but it still made me nervous.
Yorkville uses 15mm (RCA fan, Bill Woods knows what he is doing).
My local yard only has 12mm or 18mm available.
A couple of pair I made around your size were 16.5" tall (inside), the width and depth were around 36" x 30" or so.
Here s the dimension I came up with based on the 5.24 cu.ft.
L 27 1/2" x H 21 3/4" x D 23 5/8" (ext. dimension - 18mm/13ply)
Vent : L 16.49 in x W 2.24 in
Plenum : W 7" x D 16.5" x H 20 1/4"
Bracings: (1) One on each panel from vent area, rear panel, going around to the front chambers.
I wanted to use it on a portrait orientation to add height reducing the gap between mid tops and bass bin but I read some comments about the cone sag. I've also read your comment that the upright build is applicable to High Vas drivers.
Is it possible to just modify the original design (drivers still perpendicular to floor) by increasing the height while narrowing the 2 front chambers, total width based on the area of the 2 vents relocated underneath and retaining the 5.24 cu.ft volume?
I plan to have the enclosure in full grills, meaning there will be an extension of 2.5-3 cm on the front edge, will it affect the vent and plenum?
I might consider building enclosure using15mm birch ply with adequate bracings.
Djk, I saw a 15" Fane FC-153F01 driver and will try to post the full spec sheets. Seems like a very good candidate for PPSL and the price is only half of the PD.1550.
Thanks.
