A Question about SuSy and the X2
Quote from the 1998 article Super Symmetric Amplification by Nelson Pass
Su-Sy is an approach that takes advantage of balanced operation like no other design and requires a balanced input to retain the precisely matched behaviour. You can drive one input alone, and the circuit will amplify reasonably well, but it will not exhibit the very low distortion character of fully balanced operation.
Rev's 0 & 1 do not appear to use X-feedback, but assuming that the O and I of the UGS modules from Rev's 2 & 3 stand for Output and Input, it would appear that X-feedback is being used on the output gain stage. However, as the balanced inputs are converted to single-ended before being fed to the output stage, the quoted passage infers that the benefits of Supersymmetry will be negated. Am I interpreting this correctly, or am I being fooled by the mystery internals of the UGS?
My main motivation in asking this is to determine if my substantial effort to produce a fully balanced stereo stepped attentuator, and convoluted input/output switching arrangement for my CC-CCS-X-BZLS could have been avoided.
Care to comment Nelson?
The one and only
Joined 2001
The earlier X2 circuits use very little X feedback, but it is there.
The UGS module, like all the later circuits, is perfectly happy
being driven single-ended. It just takes the difference between
the driven input and the grounded input.
The initial SuSy circuits of the X600 and X1000 required balanced
inputs for best operation, but we were able to remove that
restriction in subsequent product.
:cool:
Hello M. Pass
Is It possible of driver X600 in single-end with this adaptor?
ADAPTOR, XLR PLUG/PHONO JACK; Connector type A:XLR Male; Connector type B:phono Jack
Thanks for the answer
Darry
Disabled Account
Joined 2002
Re: Re: A Question about SuSy and the X2
:cool:
Now I see there is a little X-feedback. And, I see that the Earth is round. I did not know that, when I play golf, actually I play with two balls: one small and one biggg. Yes, I should hit the small ball first and then hit the biggg ball. I do opposite way sometimes.
