Kaidanovsky said:So it makes no difference except in terms of the operating heat? If I had a 6VA transformer for example it would do the same job but just run very hot as the valves tried to draw the current?
Yep, for few last minutes in his life...
I kinda doubt it, I suspect it might hit magnetic limits first and be saturated too, not doing the same job. Though it would overheat just fine.
Wavebourn said:
0.3 m A x 2 x 15V
That should be 0.3 A * 2 * 15V... that being said, there are variations between various PCL84 regarding heater voltage, but 15V should be OK.
- Headphone Systems
- A large box of valves wants to be turned into a headphone amplifier...
