Busy afternoon!!!
you know what to do , to get ears back .........
Send that amp to me and I'll correctly dispose of it.
Hehehe
Very nice MASantos! Nice find that Panasonic THA series, 105C, 35mm.
Do the 4 terminals fit in the Teabag board? Or do you have to cut some?
They fit the boards perfectly! there were only 13 in stock at mouser.
2picodumbs, you should get in line! It looks like a apple product release at my front door!
Panasonic has discontinued ALL through-hole capacitors.
If there are any you want, buy them now.
I am now using Nippon Chemicon KMQ series. They seem to be as good as the Panasonics.
Nice amp. Congratulations.
Is there a difference between Nippon Chemicon and United Chemicon? My assumption is United are made in any number of countries and not specifically Japan as Nippon would suggest.
-The quote in you signature is hilarious without context and was probably quite funny with context.
As far as part numbers for the terminal blocks go, I don't have one but in the past bought one at Radio Shack, but not on the shelf a year later. I picked up a matching pair at Fry's electronics last week. I have more than 12 hours of drive time with 100% failure of them to have the item I went there for in stock over the last year (Fry's).
Neither seem to be metric regarding the distance between mounting holes for the chassis.
6L6 do you have a part number for those barrier blocks you use for connecting the thermistors and psu wiring? Those are quite neat!
2 Pole: 1546306-2 TE Connectivity / AMP | Mouser
5 Pole: 1546306-5 TE Connectivity / AMP | Mouser
6 Pole: 1546306-6 TE Connectivity / AMP | Mouser
Most likely no difference at all.
My feeling is (could be wrong) United Chemicon is manufactured in the USA, and Nippon Chemicon is manufactured from the parent company's factory in Japan/Asia.
- A guide to building the Pass F4 amplifier
