Jean-Paul_2 said:For Gordy,
I have in the latest version introduce a first stage CLC filter... and thanks for this contructive comments.
May I suggest LCLC instead of CLC?
Jean-Paul_2 said:the idea is to use a dual choke from Lundahl and to wired it as common mode choke...
I was suggesting that the first element after the rectifiers should be a choke instead of a capacitor. The bottom line is that I think the power supply will sound better.
Here the EAGLE PCB... Review phase.
- 427 x 280mm,
- CLC (Lundahl LL1638/10H as CMC between two 470µ),
- +150VDC to 450VDC@2x100mA,
- +6,2VDC or +12,6VDC@2x1A,
- +5VDC@1A (for µC-MMI),
- SCHURTER Vandalee illuminated switches for ON/OFF and STDBY,
- NEUTRIK 230VAC POWER-IN,
- POLARITY LED indicator,
- Amphenol 62IP DC-POWER OUT.
to be continued...
- 427 x 280mm,
to be continued...
