Hi all,
I'm shopping for the components to build my very first DIY projector. So, I'd love hear from the veterans in this forum.
Basically, I'd like to build a long-throw 720p projector with an HDMI input. I want the projector to be as compact as possible and of course I don't want to spend a lot of money for the components.
Primary Plan:
LCD: Coby 15-inch 720p TV
Light Source: 50W LED Floodlight (Cool White)
This seems like the easiest and the cheapest way to build a 720p projector but I'm afraid the 15" LCD panel might be too big. The final projector won't be so compact with this panel.
Beside these components, I will need a pair of fresnel lenses and a triplet lens, but I'm not sure which ones to get. Is there a calculator somewhere that I can use? Again, this is going to be a long-throw projector.
Another way is to buy a LCD panel + LCD controller board from aliexpress.com. They seem to have a wide variety of LCD panel & controller board that will suit my needs but the setup might get too complicated for a beginner like me.
So any suggestions, pros?
Primary Plan:
15' lcd is to big.that might be coz your box 1 meter excced
15x25.4=you need a f360 triplet lenses at least.,and larger size fresenl lenses=more money
You can choose 7-12' wide LCD.EXP:8.9 inch N089A1-L01
SETUP is easy if you want to do
Light source power you choosed is smaller. 100-200w are better.
LED=expensive,colour less, heat complex.
Why dont you go with a 10.1" panel? You can build a smaller enclosure, and using a 330mm triplet you can have a long throw projector thats small. Then go with a 300w Lamp. I have all the optical parts you need in my store. I have 10.1" panels too. Just let me know what you need.
This is my first post but I plan on building a projector myself.
I came across this site a few days ago and it is what got me thinking of building a projector.
Adafruit.com
Specifically;
HDMI/VGA/NTSC/PAL Displays : Adafruit Industries, Unique & fun DIY electronics and kits
They sell a 5.6" 720p LCD with Driver and HDMI, VGA and Composite inputs.
Not bad @ $140.
I plan on making a 480p projector to start and that kit is only $65.
Adafruit.com
Specifically;
Not bad @ $140.
- General Interest
- Everything Else
- The Moving Image
- DIY Projectors
- A first time build!
