What is a 1KOhm preset resistor because an amplifier I am building requires one. (Iam very new)
D dome406 Member Joined 2004 2004-03-30 10:48 pm #1 2004-03-30 10:48 pm #1 What is a 1KOhm preset resistor because an amplifier I am building requires one. (Iam very new) ••• More options Share S sv Member Joined 2004 2004-03-31 10:49 am #2 2004-03-31 10:49 am #2 "preset resistor" "preset resistor" means "variable resistor", which you use to tune your device once at check-out. Normally preset resistor is smaller than regular variable resistor, and is screw-driver operated. ••• More options Share Show hidden low quality content Status This old topic is closed. If you want to reopen this topic, contact a moderator using the "Report Post" button.
