Yes.
Also, to get 300-400uF, could I just use 4 100uF caps in parallel?
Yes.
Lico said:ok, I'll see how close to that I can get it. Will those resister values give me the current you said, or will I have to change anything else?
Lico said:Also, to get 300-400uF, could I just use 4 100uF caps in parallel?
Yes to both. It might even be better to parallel the 4 (or 6 or 10 - depends on the values you have to hand or can get cheap) to get 400u, rather than one. Use any decent quality electro caps for the bypass.
Edit; just saw you'd already answered, Frank
