So a PTC resistor in series with the filament would be a good idea? To prevent the inrush current to go 10times nominal... ?
Preheating ... no PTC.
No, it is in pentode mode. I don't think there would be any problems with G2 when triode strapped, look at graphs.
http://tec.org.ru/_bd/21/2115_71-.pdf
GK-71s g2 voltage limit is only 400 V.
I believe the g2 limit to look at is not the voltage in triode mode...but the current limit of the g2 as the g2 becomes quasi a mesh anode, the current can become quiet significant, but depends obviously where you set the bias.
Power dissipation, actually. Can be estimated by current graphs.
So a PTC resistor in series with the filament would be a good idea? To prevent the inrush current to go 10times nominal... ?[
The correct item for this is in fact an NTC thermistor or surge current limiter.
