You can try in:
Copernic Audio - Inicio
https://www.facebook.com/Javier.Copernic
845/211 stereo power amp finished 1.970eur
Forget 845 or other big triode as 211,805, unless its GM70.
211,845,805 are all expensive tubes even the Chinese brands and they are not military tubes, not to mention that US tubes will breaking the bank.
With the KT150 in SE you can get 13W or UL 25W w/this chinese inexpensive amp 6SN7+KT150 will made a great sound.
There is a $200 offer in coupon in this shop in 3 days.
https://pt.aliexpress.com/item/KT12...-adjustment/32459475648.html?isOrigTitle=true
Is the 1500$ amplifier going to last more than a year? if it breaks how expensive will it be to repair?
Some s.e.t. EL34 to consider:
for 1495 $The Decware Zen Triode Integrated tube amplifier model SE34I.5
Expensive is relative, for me most of Chinese amp are very expensive, 1000USD for a bad quality sound is very expensive. they use bad quality transformer, bad or fake capacitors, wires with low copper content.... I had very bad experiences with brand as Yaqin, Music Angel and Mexing Minda. You begin to upgrade the amp to increment the sound quality, the first begin with coupled capacitor, later the potentiometer, later the tubes, later is not enough, and need to change the out put transformer if want to reduce the NFB, at the end need to replace ALL. but I think that depends of how exigent is each one.Forget 845 or other big triode as 211,805, unless its GM70.
EL34 reduce budget but for me the sound is not comparable with big DHT.
Dared VP-845 Amplifier | eBay
I hope you can see the link , that was my first 'serious' tube amplifier purchase. I now prefer amplifiers which make as little 'audible' distortion as possible, focusing on phase shifts, feedback levels, topologies, Pentodes CCS, stability, and grid bias which was a real ear opener.
Correct, I cant disagree from you. In this case there is this made in AU amp made by an famous local builder:Expensive is relative, for me most of Chinese amp are very expensive, 1000USD for a bad quality sound is very expensive. they use bad quality transformer, bad or fake capacitors, wires with low copper content.... I had very bad experiences with brand as Yaqin, Music Angel and Mexing Minda. You begin to upgrade the amp to increment the sound quality, the first begin with coupled capacitor, later the potentiometer, later the tubes, later is not enough, and need to change the out put transformer if want to reduce the NFB, at the end need to replace ALL. but I think that depends of how exigent is each one.
Eric McChanson's timE Amp+ : KT150 SE UL / SET Stereo Valve Tube NEW | eBay
Unfortunately there is no internal photos.
Have you upgraded those amps and came to this conclusion?
I have test in my house the following model:
Music Angel XD800 MKIII
Yaqin MS34D
Meixing Mingda MC34
Bravo 6c33
Other brands Yarland sound horrible, Consonance the Ciber series and Melody so so, Line Magnetic sound bad, but as I said before depend how exigent you are.
I prefer to buy a second hand Airtight or make or buy a good DIY amplifier.
Theses speakers were made for me d2905/9500 and 18w8545 Scan Speak.Wow impressive ,what are those speaker Said? How did you like the music angel xd 800? Did you try to mod it ?
XD800 has two problem one is ugly and the second when you open you see that all inside are very bad, socket. wires, bias variable resistor....... XM800 is the worse of them. Yaqin is more stable, work many hours without problems.
For good quality and reasonable price, I am sure you can find a professional DIYER thay make to you in USA.
This might be of interest: Sun Valley 211/845 SET Tube Amp Kit from Japan | Wall of Sound | Audio and Music Reviews
Thanks Jazbo.
I was thinking about making this rather than modifying.
http://lampizator.eu/AMPLIFIERS/CHINA/845/new circuit from austria/ma845_v42.pdf
- Tubes / Valves
- 845 SET amp recommendations
