811A amp Class A2
My new project, 6AK5, VT-25, 811A Single Ended Class A2 amp
Advanced project, chassis perforated, tomorrow painting
hi MartinV56 ,
at first l also think cann drive or said good control of NS1000 because long time ago I was NS2000 user. NS2000 was very hard to drive!
But when my friend told me that his NS1000 stardard version & FX-1 can very easy to push.
Use 300B SE also can use. But use interstage couple will better bass.
Then I order one pair of Ebony & try to use 300B. yes, it cannot full control for classic music. But for room music & jazz, ( not heavy Jazz) it can do well. I will try 811SE & 211SE. I will continous report to share experience.
this one was very easy to drive/
Yamaha FX-1
http://page.freett.com/knisi/fx-1.html
thx
thomas
The output transformer secondary could go in the cathode circuit of the 811A and the loop feedback could be reduced . On the VT25 'dynamic coupled' driver there is no way of selecting the required bias on the 811A which may need attending to . See schematic , this amp uses a tertiary winding on the transformer to offset anode current against filament current which may be confusing , so ignore the coil marked '55t' . It also uses filament bias for the input valve which may be unfamiliar to some .
cheers
316A
