Other than the Hi-Vi D8 series (.8, +,G) does anyone know of a 8 inch (220mm) woofer that use's a 4" (100mm) voice coil? I know that companies like Dynaudio favored large VC's, but are no longer available for the DIY market. Morel has a 3" VC 8 incher but I need 4" (or larger). Has anyone used any of the Hi-Vi models, specifically the D8G?
AJ
AJ
This is a very interesting 10" with a 4" coil for 65.00 at steelsound.com . Look at the sensitivity and QTS.
Probably will need a sub below 40 cycles otherwise at this high of sensitivity(motor strength low mms) it has the making of a low compression two way - maybe mate it with big ribbon or large Heils.
Madison 10" Executioner- look under products raw speakers AJinFLA said:Other than the Hi-Vi D8 series (.8, +,G) does anyone know of a 8 inch (220mm) woofer that use's a 4" (100mm) voice coil? I know that companies like Dynaudio favored large VC's, but are no longer available for the DIY market. Morel has a 3" VC 8 incher but I need 4" (or larger). Has anyone used any of the Hi-Vi models, specifically the D8G?
AJ
Thanks Magnetar, I was doing a lot of searches amongst the HiFi "home" manufacturers without considering a "Pro Audio" type driver. Thats definately an interesting driver, especially for what I need, but other than the basic specs on their site (Madison), I could find no FR graphs, etc. I've never heard of that company before, are you familiar with the quality of their products?
AJinFLA said:Thanks Magnetar, I was doing a lot of searches amongst the HiFi "home" manufacturers without considering a "Pro Audio" type driver. Thats definately an interesting driver, especially for what I need, but other than the basic specs on their site (Madison), I could find no FR graphs, etc. I've never heard of that company before, are you familiar with the quality of their products?
I have some of the drivers being shipped to me right now. They are made in China hence the low pricing -
I have seen various good postings on Madison on other BB's.
You'll find some real sleepers among pro drivers. A large diameter coil is more of a norm than in hifi drivers.
I'll try and update this thread once I get them in some suitable enclosures. Also have some of the other higher QTS 8's and 10's coming from them to try on open baffles for 120 to 1.5K range in a three way.
Pray tell
So that I can remove the dust cap and mount a 4" waveguide loaded tweeter (non-compression, shielded) IN the throat, atop the pole. The D8G, with it's "undercut" pole, shallow profile cone, vented magnet,higher QTS, etc. look's like the best candidate so far. I'll probably have to buy the driver and remove the cap to see exactly how much room I have, since I doubt anyone here could tell me that.
http://www.partsexpress.com/pdf/297-425.pdf
http://www.d-s-t.com/scs/index.htm
D2904/7100-01
the waveguide/horn should help with the boundary effects, plus load the tweeters low end output enough to XO (steeply - 8th order +) at 1k. I'll curve the edge's of the assembly - like a phase plug - coming out of the cone.
We'll see.
AJ
D2904/7100-01
We'll see.
AJ
I have problems with attachment
Try this instead
http://home25.inet.tele.dk/meil/at.jpg
http://home25.inet.tele.dk/meil/flex_6.jpg
The number of those two are Flex Unit
6 D 102 10 20 SD and
6 A 77 10 20 SD
Only the small one are mine.
Try this instead
6 A 77 10 20 SD
meil said:I have problems with attachment
Try this instead
6 A 77 10 20 SD
Hi meil!
Do you know how these elements sound?
Are there any spcifications on these, frequency response or so??
Regards Michael
Ultima Thule said:Do you know how these elements sound?
Probably best thot of as upscale Dynaaudios or Scan-Speaks (since the fouder started both those companies)
dave
Gotcha! I type as fast as paint drying myself. Upscale Dynaudio - oh my! Perhaps I'll stick with the Hi-Vi to experiment (the're not exactly giving those away at $90 US ea.), then take the hammer to the piggybank for the Audiotech Flex units upon final design. They do look tasty.
Thank you sooo much guys, this board is a godsend
I'll run with the ideas given here. I'll try to post updates when possible. This project will take a while (like all my others), but hopefully will be complete before the sun turns red.
AJ
AJ
AJinFLA said:(the're not exactly giving those away at $90 US ea.)
You can probably get a dozen HiVis for the price of a pr of ATs
dave
- 8" woofer with 4" VC
