The gain of a real "anode follower" can be adjusted from maximum gain to unity gain by the ratio of two resistors in the circuit. Please don't use the term "anode follower" to designate a normal grounded cathode amplifier stage : it muddles things up and reduces the number of useable designations just as Bruce Rozenblit has with his misuse of "grounded grid".
Not inherently drastically so, you can't. Tweaking current will be still about there for gain, only funnier working points. If you want an input Lpad, I don't advise it on transparency grounds, ups source impedance and interaction with Mr. Miller. Go buffer and listen first.
hi salas,
i tried 10k anode resistor and it sounded much better.all of the frequency spectrum opened up especially the bass. the harshness was gone and most of all i now have a usable range on my volume pot. what happened when i made the change?i know that increasing the load lowers THD. do i need to change the cathode resistor value if so what?
happy new year to all,
ivan
ivan
hi salas,
ivan
In my case 5k was best, had tried 10k too. If your amplifier does not mind higher source impedance, then the THD with 10k is surely less, and you must have lessened the current also. OTOH the gain is supposed to go up? Then you use it as I/V so I don't know. What kind of voltage you got across Rk, and on plate, with how much B+? So to see on the chart. The main idea is to use the 6V6 as a triode line amp, find your best load and operating point in your system, by all means. Which make of 6V6 you got? The buffer arrangement has the less THD of all due to local feedback BTW. Cheers, happy new year.
Anything that can give 100mA at 400V without stress will do. So about 340V will be feasible counting the Vdif needs of regs. 45mA is for two channels, but 100mA is good for headroom or in case of shunt reg extra constant current needs.
Thanks.
How much current the Maida regulator draws and what's the minimum voltage drop across it?
No, the filament goes up slowly since its a current source heater, the tube rectifier goes faster but rather slow enough too, compared to ss diodes. Haven't experienced any early wear due to cathode stripping yet. Of course the slower the rectifier tube, the best in that regard.
Salas, you feed your 6V6 line stage from Maida-like series regulator. Yet, in your "Simplistic Mosfet HV Shunt Regs" thread you say that the Shunt regulator sounds much better than the Maida one, which makes a lot of sense. Usually, when all else is equal, shunt regulators are much better and quieter than series ones. So, wouldn't this 6V6 line stage benefit from Shunt regulator?
I'd rather start the project with one type of regulator and I trust your experience.
- Tubes / Valves
- 6V6 line preamp
