Unless dropped too low these resistors don't set gain, but they do set the output LF point. Reducing R increases the output LF point, which reduces the amount of supply rail subsonics coming through to the output. In some cases, of course, the input resistance of whatever comes next will determine the LF point.
Try grounding the filaments more by jumpering the 47k resistor.
Interesting idea, easy to test. - so simply replace R8 with a wire?
NO! Actually there is a 10uF cap at that node expressly to provide a low impedance to ground - if you short that resistor to ground the filament to cathode insulation in your 6SN7 may fail. (Check the cathode voltage on the upper tube and if it is near or above 100V this is ill-advised.) Further this is unlikely to have anything to do with your issue, and necessary practice with single envelope dual triode based SRPP and mu-followers.
Please take a look at your plate voltage and compare it to the wander you see on the output of your line stage. Reducing the size of the output coupling cap so that it is -3dB at roughly 10Hz ought to be adequate protection. Consider adding a Maida style voltage regulator for the B+ if you are that concerned - having verified that your B+ is wandering of course.
Heater negative with respect to cathode is 200v for 6SN7. Measure your cathode voltages. My guess is you will be more than fine.
True from a data sheet perspective, (at least RCA HB3, and Sylvania 6SN7GT data sheets) direct experience with Sylvania and GE 6SN7 over 20yrs indicates that problems can start with as low as a 100V - 150V difference. I'll admit I've not had a very high failure rate, just a few here and there, but enough have failed to leave me questioning that rating. Modern production tubes IMLE are much worse.
And tungsol, however I bow to your experience.
Whenever I see AC filaments.....its the AC filaments.
Actually often my experience too. It did not initially register that the filament supply is not DC.. Easy enough to fix.
Actually, the filament circuit seems easy enough for me just to attach a 6v dc lead acid battery to the AC 6-0 terminal on the pcb! This could reduce the noise floor quite easily!
I also have a simple filament regulator:
http://www.ebay.com.au/itm/220951565373?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
But the 6.3vac winding on the transformer I am using for the 6SN7 SRPP obviously doesn't allow me to get enough volts out of the regulator circuit - is there any way around this?
Yes. Low drop-off regulator, for example implemented with MOSFET as a pass element, and Shottky rectifier.
Look whats new from Linear Tec.
LT3022 - 1A, 0.9V to 10V, Very Low Dropout Linear Regulator - Linear Technology 0.145mV drop. <= Ultra low drop voltage regulator....for all your 6.3 volt problems.
It might not be that new as I have not looked for awhile. You should be able to easily get 6.3v regulated out of a 6.3v AC tap with this.
Good part, but using 1 MOSFET, 1 BJT, couple of resistors and one Zener I can get much more than 1A. Well, one more Zener is needed to protect gate, since I provide 1 mA current from B+ rectifier through resistor.
1uF seems rather large for feeding a 470K load - the input LF rolloff will be at 0.34Hz!! As a result, the LF rolloff (actually a shelf) will be set by the 220uF cathode bypass caps at around 3Hz. This breaks two of the rules of good design: set the LF rolloff early on (before subsonics get a chance to cause IM), and never set it with an electrolytic or other nonlinear cap. I would reduce the 1uF to 0.1uF, and consider doubling the 220uF to 470uF.
What happens if the preamp is connected to, say, a solid amp with a 10k input impedance?
This is how I have always tested tube pre-stages: with a solid state TA2024 amp and some terrible speakers from an old sound surround system. At least then it magnifies and hissing/humming noises and assists (in the absence of a scope) of testing what changes in sound arise from changes in the circuit.
I let the unit run for about three hours last night and can confirm the noise levels are now really low. There appears to be some junk on the tweeters - should I install some RF filtering or LF bypass caps? I recall when building my DAC I soldered some 6.8nF caps at the output using these calculations:
1/(2 * 3.14 * 1000 * 0.0000000068) = 23.4 KHz
So the value was 6.8nF (0.0068uF)
Is there a similar low pass method used for line stages?
If the 10k was maintained down to DC then the 4.7uF output cap would give an LF cutoff of 3.4Hz (ignoring the SRPP output impedance). OK, provided that the 4.7uF is not an electrolytic.directdriver said:What happens if the preamp is connected to, say, a solid amp with a 10k input impedance?
You could put an RF filter at the input if interference is a problem. Most people would regard 23kHz as a bit low for a low pass filter, except that a DAC has special requirements.lordearl said:There appears to be some junk on the tweeters - should I install some RF filtering or LF bypass caps?
I would reduce the 1uF to 0.1uF.
To clarify - was this in reference to C5 and C12?
- Tubes / Valves
- 6SN7 SRPP - oscillating dc offset
