6sn7 pre
hello,
I look for a link to this schematic. Can anybody help me?
drobert
What is unclear?
you have a power supply which will deliver ~240V. The 6SN7 runs its heaters on AC. It has ~6kOhm output Z( excepting where the coupling cap takes over and dominates at lower frequency ).
You should be able to get it working almost anything which is even close to what is described on that schematic.
I'd suggest a higher B+, and double the plate load resistor. 32-34kOhm is a nice load line when B+ is ~440VDC. Drop 250 of those volts across the plate load, for about 6-8 mA.
cheers,
Douglas
