I found this (chinese) 300B PP amp, using 6SL7 as first tube (and 6SN7 as driver).
But doing a drawing of the internals, I find the 6SL7 connected as one triode (both in paralell).
The 6SL7 has a touch much gain, so a 6SN7 does the job almost just as good...
Now, I was thinking, is there a single-triode (octal) 6SL7, or something between SL and SN, or would maybe a 6J5 be a simpler sollution?
Arne K
Arne K
The 6SF5 is octal. You can also just use half of the 6SL7.
This would be the simplest "upgrade", I think. But, since it has a tad too much gain, would a 6J5 (and maybe a reduction in feedback) do the job better?
Arne K
6SQ7 is interesting, but not in my collection (yet)...
Arne K
hey-Hey!!!,
I'd consider an octal-nine pin adapter and apply a single 6S3p Russian single for your 6SL7 stage. mu is ~40 so you'll loose jus' a bit of gain.
cheers,
Douglas
CCS... - source or sink?
I have some CCS-pcbs ready, what is their best use, source or sink?
The LTP (splitter) was my first choice...(?)
Arne K
Both! For the plate load in the 6N2 and cathode 'tail' in the 6N1 section.
cheers,
Douglas
- Tubes / Valves
- 6SL7 alternatives?
